Under Hood Garage Sale
zonker
I am cleaning out my under hood bits and pieces that are not needed anymore.
Power Badger Engine Heat Controller Brand new. $90 ea. I have 2.. one in the box and one not but never used. More than just a timer, the Power Badger™ is a block heater controller that does the time calculations for you, based on actual outside temperature.
Saikou Michi Catch Tank $100. Brand new never installed. This is truly the finest design and constructed oil vapor catch can. I have had 2 installed and they really do there job. Also add a drain line down by the oil pan and when changing oil.. just open the drain valve to empty into oil drain pan.
Summit Racing Trans Cooler $50. Excellent condition even tho installed briefly. It worked way too good and lowered the trans temperature a little more than I wanted.
Slee Factory Light Switch STF1036 $40. Brand new. I believe it was for my 80 series which I sadly no longer have. Slee no longer has it listed so could not verify the model usage.
If you are interested in buying any of these bits. Just send me a zip code and I will get you my cost to ship. I take PayPal for the purchase.
