Ram 5500 tradesman with 12" touch Nav screen - 6.7 Cummins deisel. 84" Chassis - liquid springs. back hitch 17,000 lbs - Full coverage front bumper with cutout square for square lights, front hitch, and 20" light bar cut out.
Back seats have been removed and platform with storage & 4" memory foam mattress. Neoprene diamond stitched tan seat covers, full weather tech floor mats in brown, weather tech window shades all windows - + back seat dog door protector. Currently running dually tires. 3500 miles on truck.
Price is $250,000 (does not include interior build of kitchen cabinets, couch, flooring, super singles or paint job for habitat. This is a partially finished expedition vehicle to design how you'd like either yourself as a DIY for a far less of a cost than the normal $400k+ trucks...or have it professionally done by your own builder
The Truck is currently being built with the following which is included in the price.
24 VDC to 12V 100AMP, Blue sea, Victron, Anchor and various other components, Marine grade wiring & components used throughout, 15amp exterior AC power outlet, 30amp shore power plug, 12v and 110v outlets)
- Extended cabover (72.5") habitat
4 point articulating frame mount system with aluminum storage boxes - Passthrough from cab to camper
- Roof rack that integrates solar panel mounting and recessed awning mount
- Passenger side rear gear garage
- AT Euro entry door
- Torklift entry steps
Led exterior lighting and vehicle lighting - CareFree Colorado legless electric awning
- AirFlo mattress ventilation
- Dimmable interior LED lighting
- Wet Bath in entryway with vent fan, hooks, retractables interior shower door, slideout compartment for toilet
- Partially finished passenger side and drivers side "kitchen area" with flush finish sink and area for electrical and other components (we can provide aluminum/honeycomb framing in other areas as desired)
- LiFePO4 off grid Electrical system with "stubbed" wires for customer convenience (600ah 24v battery, 1200/1500w of bifacial solar, 3000va Victron 24v multiplus inverter/charger, Victron Phoenix 800va inverter for small appliances, Victron smart MPPT solar controller 100/60, Victron CerboGX with GX touch 50 monitor, Victron Lynx Shunt, ×1 Lynx power in, x2 Lynx distributor, 50amp Victron Buck Boost Charging via alternator, Victron Energy Orion IP67 DC-DC Converter
- 24v Undermount AC with integrated hydronic heating
- "Unlimited" hot water from hydronic heater
- ×4 large AT windows, x2 medium AT windows in cabover, ×1 premium roof hatch (window in door as well)
- Maxxair roof fan
- 85 gallon fresh, 47 gallon gray water capacity in insulated subfloor, with integrated redundant heat systems and premium water pump and accumulator.
- Mount customer provided Starlink system (Roam/high speed recommended)
an 360 degree camera system
