Victorian
We created something unique for Kei truck enthusiasts!
As these Japanese import trucks gain popularity we thought why not introduce a brand new incredible well insulated box for these trucks.
Originally our factory designed and build these to very strict Japanese standards for OEM upfitters in Japan. Regularly, these boxes are just a couple of inches shy of being big enough to sleep inside....
We tweaked the dimensions a bit and now have a 6' interior length. At only 150kg/~300lb and 2" PU FRP walls (R 14 insulated) we think that this would beat roof top tents all day long in terms of comfort and safety.
Currently ONLY available for pick up in Canada @ CAD$ 5795.00
In any case, here are the full specs:
Bare Shell · Food-Safe · Micro-Camper Ready
This is a brand-new, super-lightweight insulated composite cargo box designed specifically for kei trucks and expedition upfitting. Weighing only ~150 kg, it delivers serious versatility without overloading your rig.
Whether you’re building a food-safe refrigerated transporter, a mobile service unit, or a micro-camper, this box is a rock-solid foundation.
Pick up in Victoria or Freight to be calculated at time of purchase.
Link to images and online purchasing: https://www.expeditionupfitter.ca/c...-insulated-composite-cargo-box-for-kei-trucks
WHY THIS BOX WORKS
- Ultra-lightweight (~150 kg) – ideal for kei truck payload limits
- R-14 insulated composite construction – excellent thermal efficiency
- Food-safe interior – ready for refrigeration or clean cargo use
- 6 ft interior length – long enough to comfortably sleep inside
- Barn doors for easy access and loading
- Integrated 3rd brake light for safety and compliance
BUILD IT YOUR WAY
- Add a reefer unit for temperature-controlled food transport
- Convert it into a micro camper (sleeping platform, insulation already done)
- Use it as a secure expedition cargo box for overland travel
SPECIFICATIONS
- Construction: Insulated composite
- Insulation Rating: R-14
- Weight: ~150 kg
- Interior Length: ~6 ft
- Doors: Rear barn doors
- Lighting: Integrated third brake light
EXTERNAL DIMENSIONS:
- 190 cm (L) × 129.5 cm (H) × 142 cm (W)
- 74.8 in (L) × 51.0 in (H) × 55.9 in (W)
IMPORTANT NOTES
- Listing is for the bare shell only (no interior build-out)
- Box is new and unused
- Barn doors and third brake light are pre-installed
- Pickup available in Victoria, BC (Canada).
- Freight to be calculated at time of purchase
