AZTrooper
Ok, hopefully this will be an easy question. Since I lifted my trooper two inches, the 265/75/R16's seem a little small. So I want to put some 33s on it. Anyone know how much that would effect the gearing. I believe my trooper came stock with 4:33s in the rear diff. If that's the case, then I shouldn't need to mess with rear diff, but upgrade my transmission. Is there a transmission that I can get that has lower gearing that will swap directly into the stock transmission spot?
