Imbuere
I plan on running a single positive 4 AWG cable from the battery to the rear area where there's currently a cigarette lighter. The rating of this plug is only 15 amp and I worry about it's long term viability as my needs expand. I also like to have things hard wired rather than cigarette plugs, so I'll be replacing everything with Anderson Power Pole connectors. I plan on using this for the main source of power on the rear and inside of the cabin. I hope to find a good body ground for the negative cable rear the location I will put a Blue Sea systems fuse block for distribution. I can use the cigarette lighter as an ignition lead on a relay for anything that I want to be ignition only.
Any drawback of this? I feel I know just enough about wiring to be dangerous and am a tiny bit worried about screwing something up.
