2020 Turtleback Getaway Trailer
*Getaway Chassis - Welded 2x3 Galvanized tube steel chassis
*Front and Rear 2-inch receiver hitches
*Timbren 2000HD Axle-less Trailer Suspension to accommodate 5 or 6 lug hubs
*Trailer break-away brake activation switch, LED yellow and red side marker lights, LED brake lights, signal lights, and running lights. Integrated reverse lights, adjustable rear stabilizer (required for disconnected hitch use), dual towing safety chains.
*7-pin trailer connection- unclosed charge line, brake controller line, running lights, signal lights and reverse lights
*Turtleback adventure/getaway 11-gauge aluminum main box, rear door, and nose box
*Nose jack 2000 LB swing away tongue jack
*3 16-inch pro comp steel wheels with BF goodrich ko2 265-75R16 tires
*Adventure / Getaway tailgate with 2 receiver - single swing out tailgate, built in 2 universal use hitch receiver for bike racks, ETC, Two- position locking pin, rated for 125 LBS. Jarry can Mounts included. Swing out spare tire carrier
*Expedition spare tire
*Gaw side door- add on x2
*Upgraded roof rack- 4 rail cargo/rtt powder coated steel rack with storage area for 30 wide picnic tables, chairs, etc with single rear door mounted in roof rack assembly.
*Getaway electric & lighting system - Ground lights, nose box lights
*1000-Watt inverter System
*Getaway Solar-ready kit - ZAMP 15 AMP solar controller w/ battery status indication, voltage meter, nose box mounted SAE connector ready for solar panel selection
*Sun Power 100-watt solar panel
*Dual battery electrical system - GXL 125 degree C automotive wiring, blue sea marine grade components, dual trojan group 31 AGM deep cycle batteries for a combined 210-amp hours of power, battery boxes, blue sea 6 circuit fuse block, blue sea dual battery disconnect switch, 6 AMP heavy duty battery charger (shore power)
*23ZEROabout 72 rooftop tent (king bed) with light suppression
*23ZERO rooftop tent sheet 72
*23ZERO walkabout 72 short annexes
*23ZERO peregrine 270 awnings with light suppression
*23ZERO Ladder Rung Covers
*23ZERO Universal Boot Bag - pair
*23ZERO Universal Gear Loft
*Stainless steel anti-theft security nuts on tent mount
*Fold down metal table mounted on interior swing out tailgate
*2 Nato style 5gal fuel cans
*1 Nato Style 5gal water can
*Articulating (off road) hitch
*12v refrigerator
*2 Slide out cargo trays
*2-Gal propane tank
*Turtle basic spare tire Trash-A-Roo
*12v refrigerator
*2-Gal propane tank
