ReluctantTraveler
I'm planning to build my rig on top of a flatbed using marine-grade plywood and rigid foam board insulation, with a wood frame (similar to what IdaSHO has done with his camper).
I'll be gluing the whole thing together with SikaFlex or something similar. Is there any reason not to use screws at the edges and corners to hold things in place while the glue sets up?
I planned to glass or silicone over them before painting to seal the holes up. As an alternative I could use brad nails, but "glue and screw" seems a bit more sturdy.
