I’m starting with something similar. I’ve chopped about 15” off the top. Although mine has bifold doors on the rear. In fact, I think it’s the same trailer, just modified.
Looks like a perfect setup. Like said above, a bit on the heavy side, but if your truck is fine with it, great base to work from. Honestly very little needs to be done. Enclose the main area, add some ventilation and lighting, done.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
