UZJ100 snow handling.
Pskhaat
2005 Expedition Trophy Champion
After several days of snow and ice, when the skies cleared I took a fun 9.2 mile up & down mountain road to see how the UZJ100 does in the snow. It's normally nothing to write home about in any Cruiser. The route is here and is only 1800 total altitude delta:
http://maps.google.com/maps?f=d&hl=en&saddr=39+40%2725.88+,+-105+26%2741.03&daddr=39+38%2711.93+,+-105+23%2751.42&sll=39.654738,-105.421886&sspn=0.063702,0.11673&ie=UTF8&z=13&ll=39.655267,-105.4212&spn=0.063702,0.11673&om=1
What I found on my descent shocked me. The 100 is a completely different off-road animal to many 4WDs and previous Cruisers. On the steeper switchback turns (see North side of route) I very nearly went over the side of the road until I got a good feel of the 100, as the 100's rear end likes to slide out. More on why later.
To maintain any level of speed (I'm still talking very slow speeds here) and for those accustomed to winter driving, you almost need to delay corrective steering action during the slide turn in order to keep the 100 in it's intended track albeit at an angle, as early/natural correction will put you on the outside/falline track. I won't be brave enough to call this drifting, but in effect it is it's slight form.
The reason I believe the 100 has such an easy rear to break out is that in light braking, the rear calipers receive a greater bias of force. Hader braking will transition the force more to the front of the vehicle. This is accounted in this thread on another forum:
http://forum.ih8mud.com/showpost.php?p=1294481&postcount=1
The problem with winter ice+snow driving downhill is that if you don't fall in the perfect downhill gear which is very difficult for longer variably sloped hills, there is still some braking to be done. One dare not apply too much brake as to cause ABS enabling which will IMO hinder braking even further in these conditions plus the delay in ABS shutoff. There is control to be had in a locked wheel when you know when to use it. Digressing, but you still will be applying some sort of braking which often immediately precedes the turn especially if you are on an unfamiliar road or at night where turns may creep unexpectedly on you even in safe & conservative driving.
Since the rear brakes have the bias more during these winter conditions in addition the already less orthogonal rear weight due to the incline plus the forward suspension shift during slowing: IMO it potentially causes an unnecessary rear end slide during tight cornering.
My sister-in-law years ago complained of this in her Hundy, but I never gave her due credit until now. This is definetely something for which to watch out.
Wondering if you think this has anything to do with the lift? I know lifting my truck made the F-to-R bias wrong until I got the rear proportioning valve set right. What tires are you running?
The 100s don't have the manual valve, it's all done through the electric brake system. That said, any object dually-afixed to a sloped surface and orthogonally extruded will have its statics adjusted; but both front and rear at 2-3"? I'd have to pull out the E2 paper...
The XTs, which granted are not as good as say a GY AT/S, but I've run the 80 down that hill taking a shortcut to town with the same tires in worse conditions without a second thought.
Oh yeah, and mountainpete, this to date is the only real complaint I've had of the 100, don't let this one decide your Cruiser fate, it's just a `feature' of the electric system that one has to get used-to. I will say that the 100 stops on a !@#$%^& dime, it's like stopping a motorcycle it's so amazing. Save this tidbit, best brake system I've ever driven.
It's an important perspective for me Scott! Remember that up here we are driving on snow a good part of the year. I need to do some more research on TRAC though...
pskhaat said:
1999, non traction control.
I don't have a ton snow experience... After reading your post I was thinking about TRAC and how it might effect you in the same situation. Any thoughts?
We had 4 inches of snow and ice yesterday. I drove the 100 around on the unplowed roads. Many of the neighbors were stuck at the bottom of the hill in their cars and I took them home. Up and down the hill several times. I didn't experience anything odd or unexpected. So far, I've had good results with my LC on the road in snow/ice/rain conditions this winter. I'm using Yokohama Geolander ATII's. Not the best in snow, but pretty fair.
I'll try and see if I can get the rear end loose next time it snows. I know a perfect hill to try this on. Stuff is almost all melted already this time. Maybe a firmer application of brakes is needed?
My expectations are also unreasonably high :| The total road grade is about 9-10% with constant switchbacks. Certainly not that extreme, but tame enough to expect road speeds.
I really try and get to know my vehicles though; at least I like to tell myself that the knowledge helps me out and maybe has saved me a few times. I really havn't had much time with the 100 in true winter conditions, so it's certainly my first time with the truck like that. Just things you get to learn.
tbnd88
