VENTER TRAILER Off Road Custom
VENTER TRAILER
Imported from South Africa
http://www.ventertrailers.co.za
Includes VENTER Compression Braking System
5-Bar Chequer Heavy Duty Plate Landing or Staging Area on Trailer Roof at Tent Exit
Box 83” x 45w x 31” tall at center
131” tail to hitch
66” wheel outside
14” axle clearance
3” Lift Kit
Defender Land Rover Alloys
MAXXIS - BIGHORN 255/85R 16” https://www.4wheelparts.com/p/maxxis-lt255-85r16-tire-bighorn-tl28394000/_/R-DLDG-TL28394000
Battery power with 4,000 watt inverter
Solar Power Drip for Battery
Support Scissor Jacks (rear)
4 Four Jerry-Can Mounts / Cages (Locking)
ARB ROOFTOP TENT
https://arbusa.com/tents-awnings-camping/rooftop-tents/
5-Bar Chequer Tread Plating Covering most Vulnerable areas
Custom Roll-Bar resembles NAS Defender Exterior Roll Bar
AT Overland Equipment Chaser Trailer Table Shelf - The shelf is made from 1/2" Baltic Birch, the edges are routered and the corners rounded, it is finished with polyurethane. The shelf locks in place between the fender and the flare of the box, with the help of two location pins.
18" W X 47"L X 1/2"D. http://store.adventuretrailers.com/products/Chaser-Trailer-Kitchen-Shelf.html
AT Overland Equipment - 5 lb. Propane Cylinder Bracket. AT’s aluminum propane bracket, sized to fit a 5 lb. propane tank. Compact and light weight. - http://store.adventuretrailers.com/products/5-lb.-Propane-Cylinder-Bracket..html
Slide-out Refrigerator/Ice Box tray
Rear-Drop Gate Storage
2 Piston German Made Stainless Lid Lift Kit
Battery & Inverter Installed; Never Used
Kitchen kit not included
Extensive Storage Capacity
Ping Kris at 714 615 7605
Located in Phillips Ranch/Pomona CA
$6500
Top Jimmy
