Vibration problem
Pitchpuller
I recently installed the 2 inch OME lift to my 2011 Tacoma. I added the extra rear leaf springs for increased load capacity. Even with shims installed for the rear axel I still have a slight vibration in the drive train. Any ideas or easy solutions out there that I'm missing?
ywen
very difficult to troubleshoot.. could be caused by a number of things.. you need to narrow down the vibration in the way you reproduce it... What you've described so far, there is no way to troubleshoot.
search on tacomaworld... lots of issues of vibrations with tacomas.. the front diff is a weak point, esp when you lift it..
whitetaco02
Did you get it aligned afterwards? Diff drop?
Try taking the shims out. With two inches you may not have needed it done.
4xCoffee
