Victron and Battle Born Parts
steezeman
Located in Logan, Utah. Local pickup only for now.
VICTRON PARTS
I've been running this equipment in my Toyota Tacoma for the last year. It works great, but I'm working on a new system that will better meet my needs in a small truck. It's all in good condition, and should last for many years. I'm replacing it all with victron equipment.
1x 500A SmartShunt ($50)
[SOLD] MPPT
___12V equipment___
$150 each, or $500 for all four
2x ISOLATED Orion-TR DC-DC battery chargers 12V to 12V at 30A
2x NON-ISOLATED Orion-TR DC-DC battery chargers 12V to 12V at 30A
These were connected 2S2P to the house battery, with the isolated chargers "stacked" on the non-isolated chargers. It worked but was over-complicated.
___24V Equipment___
This is all 24V equipment, most won't have a use for it. If you need it, you already know.
1x Orion-Tr 24V to 24V at 12A (this is a great device for eliminating flickering 24V LED lights when large loads turn on/off) - $100
1x Phoenix 24V pure sinewave inverter 1200VA - $175
BATTLE BORN BATTERIES
$1900 for the set. Will consider selling individually. Set of four battle born LiFePo4. These have the self-heating feature. I've had them installed in the cab of my Toyota Tacoma for about a year, while I was living in it and traveling all over the continent. They are rated for 5,000 full discharge cycles. I'm confident that they have been used less than 500 cycles. They have been used for that full time. Never shorted or left at a low SoC for more than a few hours. Never used to start or jump an engine. Always charged from solar or the alternator via a Victron Orion DC/DC charger. If treated well, these should have another 10 years in them. Just a little dusty from bumping around on forest roads all summer. I also have some custom laser cut brass bus bars available if you're interested. I was running these as a single 2S2P 24V pack, so I have one set of bus bars for that configuration. I also have a new set of bus bars that will put these into a 12V 1S4P configuration (ordered, they are in production and should be done in a week) I'm selling these because I designed a new system and these aren't a part of it.
steezeman
Here's what the install looked like.
steezeman
Victron Inverter and shunt are SOLD.
All DC-DC 12/12 chargers and the 24/24 converter are still available
Gatofoamball
