Vinyl plank flooring.
Poul.dubai
I have decided to use a vinyl plank flooring, color espresso brown, I feel it’s very durable and easy to install, it's from a company called, Gerbur Global Flooring Solution, this type is called Evolution Extra Wide LVT Click Plank, you don’t need to glue it but I have to due to the folding end wall that will use as a balcony.
but first, the Copper pipes for the water are cut into the insulation.
All weld is tested with water pressure for any leak before adding the plywood.
It goes fast to lay down the floor very easy to install.
Cut out for the shower pan.
Working around the GoPro, few time-lapse videos are taken.
Water pipes for the kitchen sink mixer.
The red hose is to equalize the 2 water tanks.
The Platform has a lighter vinyl plank color is called cappuccino.
The next will be the bathroom & toilet.
Cheers.
Camp Tonneau Tents
