Vtuned performance tuning box VR Tuned ECU Tuning Box for Mercedes Sprinter
Had intent to install but kind of forgot about before selling the Sprinter.
Never used, new in Box. Read about it here
New is $650. Selling for $400 and I can ship for free.
Vivid Racing
SKU :VR-VRT-525908
VR Tuned ECU Tuning Box Kit V2 Mercedes Benz Sprinter 219 CDI BlueTEC (W906) 188bhp 2006-2019 - VRT-525908​
Get your Mercedes-Benz Sprinter (W906) 219 CDI BlueTEC tuned with the Version 2 tuning box kit from VR Tuned. The tuning box kit is a plug and play solution to boost your vehicles performance up like an ECU flash, but without affecting your warranty. The VR Tuned ECU Tuning Box Kit gives your Mercedes-Benz Sprinter (W906) 219 CDI BlueTEC a gain in power from 188bhp to 240bhp!
U/MOriginalTunedIncrease
KW140179+ 39
BHP188240+ 52
FT/LBS325407+ 82
Features:
  • Made in Germany
  • Plug and Play for easy install and removal
  • No detection by dealer when removed
  • Up to 7 different maps for easy programming
  • Includes bypass plug to run as stock
  • Does not lock to vehicle or VIN
  • Harness has OEM style connectors, no splicing or cutting
  • Tuning Box features a weatherproof case
  • Digital Microprocessor Controlled
  • Proven power gains tested on 93oct/98ron.
  • Designed for forced induction vehicles only
  • Tuning box cannot eliminate CELs caused by modification or removal of emissions control devices such as catalytic converters.
  • Download Installation Instructions Here
Specifications:
  • Make: Mercedes-Benz
  • Model: Sprinter (W906)
  • Years: 2006-
  • Capacity: 2987
With manufactures trying to increase fuel economy by adding forced induction to vehicles that previously had large displacement engines, the ability to tune them further is even more prevalent now. However there are 2 main issues with tuning these newer vehicles. The manufactures have gotten very particular about having their ECUs accessed to be tuned. These "anti tuning" features make it hard to read and write the ECU via the OBDII port. Some ECUs can be removed and flashed on the bench once the case is open. This is an immediate flag to the dealer which ultimately will void your power train warranty if a situation arose. This is where the VR Tuned Tuning Box Kits come into play over the competition.
Engineered for boosted cars, these vehicle specific plug and play kits are designed to easily be installed and uninstalled as needed. The harnesses feature OEM plugs that attach to necessary sensors where the pre-mapped tuning box gives your vehicle huge amount of performance gains. Unlike other "piggyback" solutions, these use high quality connections, wires, and casing that are designed to be engine mounted for longevity to the elements.
Each Tuning Box Kit has been engineered and tested to work in even the most extreme environments of altitude, temperature, and driving conditions. If you have any questions in regards to the VR Tuned ECU Tuning Box Kit for the Mercedes-Benz Sprinter (W906) 219 CDI BlueTEC 188bhp, please contact one of our Performance Specialists.
scotty59
