Waeco questions
890man
I just picked up a nearly new CF-35 off of craigslist for less than half of the lowest retail price I was able to find!!:victory: The thing is perfect. Its smaller than I wanted but the price was so good. It didnt come with a manual though. Does anyone know where to find one? I have had no luck. I really only have a question about the " High Med Low" switch and the emergency " on Off switch. I believe the first switch is a setting to conserve the battery preventing too much drain but don't know what the positions are for. Thanks for your help.
Tucson T4R
The manual linked above should give you the specific cut off volatages but that Hi-Med-Low switch is for selecting what battery volatge you want the fridge to cut off at to protect your supply battery.
If you have a dedicated deep cycle supply then set it to low. if your battery supply is your primary starting battery in the truck then set it to Hi.
dhuss
