Water Storage in a Body Channel?
Anyone ever stored water in a PVC pipe or similar?
I have an idea...
Tundras, and probably also Tacomas and 4Runners and a lot of other "body on frame" vehicles, have a large hollow channel under the lip of the door...it's the section that hangs down over the frame on the outside like the skirt on a hovercraft. The body pinch weld is what holds it together, that's the part we protect with the main rail on a set of rock sliders.
Both ends of this channel have a rubber grommet to keep water out, removeable so if there's a lot of water inside it can be drained. There are other holes along the length of the channel, also for drainage/breathability.
When the wheel well was tubbed, it was apparent there's a LOT of room in that channel. I didn't measure at the time, since I wasn't thinking of this, but IIRC a tube between 3" and 4" OD would fit the entire length of the channel, which on my truck is at least 72" long.
Making a couple quick assumptions regarding storage diameter, a 3"x72" volume in gallons (231 cubic inches per gallon) is 2.2gal, 4"x72" is 3.9gal, that's per channel. I think it's closer to 4" diameter, it's a large space. Those numbers are rough guesses. If I can fit at least four gallons in each channel, this might be worth it...I think the space is actually longer than 6', haven't measured yet.
There is a very large grommet in the back (~1" dia) of this channel. It would not take much work to enlarge the hole and shore up the area around it, preferably with a piece of tube scrap larger than the end cap of the storage pipe going in the channel. The storage pipe could be fairly thin, whatever could stand 6' of water pressure would suffice.
Pumping the water out would be easy, preferably non-motorized, mounted in the aft end cap (which could be exposed behind the cab, there's plenty of space between the cab even with a 40" tire on a Tundra), and use either positive pressure (like a super soaker) or a regular pump (normal squirt gun). I figure a regular pump with a filtered air return line would be better, so there's no risk of overpressuring and bursting the pipe.
The location is as low as you can get on the truck, balanced between front and rear suspension, and tho spread wide if it were set up to draw equally from both tanks, the weight distribution would remain equal side to side (water is 8.3# per gallon, or in this case 3#/ft to 5.4#/ft...not much--probably max 35# per side, distributed more or less evenly). It's in a position where temperature will be determined most by environment, not exhaust or cab temperature, so freezing might be a problem without some sort of heater element, like those resistors for outdoor water bowls or something. Getting it in and out should be fairly easy, but I think will require taking off the rear tires...not a big deal since tires are easy and the tanks would only be in if they were going to be used...or I could just leave them in, if they're clean. It's also protected by the sliders from the bottom and sides.
The parts I haven't figured out yet are how to determine water level, which end would be best to draw from, preventing sloshing/overpressure during acceleration or hard stops, and how to firmly secure it.
Drawing from the middle would be a bad idea--hard to get the last few drops out--but drawing from either end would be easy as the level dropped. When the truck is unloaded, the nose is down. Loaded, it's either level or the tail is down (my bad...unpack and try again...), and if you needed to put the nose or the tail a little higher for a minute or two, it's very easy with the hi-lift if you're not already on uneven ground.
No idea how to guage water level with this setup...just use, I guess. I like to take more water than necessary anyway, so this would be used only for hydration and first, and with relatively reckless abandon...I'd rather be well-hydrated and end up drinking from a jug in the bed toward the end of a trip (or just refill the tanks on the fly). Maybe a small flow guage or pump counter or something.
I think a couple fins with small openings at the very bottom would prevent sloshing, sorta like valving shims on a shock...water can move end to end, but not too fast. I could do it with something as simple as a couple lengths of non-corrosive wire and a few pieces of thin plastic.
Also not entirely sure how to secure the storage tube. Best bet I think would be three attachment positions, some sort of ring clamp or similar device, with one at each end and one in the center.
For a visual reference of where this is on a truck, look at the bottom of the door line on a Tundra, Tacoma, 4Runner, etc...it's the space in the body channel right behind and under that door line. It's easier to see with the door open, from an angle looking up at the frame.
Thoughts, opinions, suggestions? If this can work, it'll free up a good chunk of space in the bed for toys and other stuff as well as distributing the load better.
*edit* after looking a little closer, it might be closer to 3" diameter, max, than I remembered. Not sure if it's worth the trouble after all :(...there are other places, like over the sliders next to the frame rail, that could work equally well with less difficulty...
-Sean
hey i still like the idea!! even if it was just between the fram and the sliders its a good place to mount a tank. has anyone ever mounted tanks in the sides of the bed? there is a few inches of gap there and on my truck (an 85) whole whole inner part of the bedside removes with a few bolts.
inserting a pvc pipe made for water is a good step. If you are just pumping water into a cavity on your truck, I would be very afraid of leaching from the surrounding material. Just make sure what you are using to contain water doesn't leach. Think paint, plastic, grease, epoxy, metal filings, etc...all these stuff can be inside your cavity ready to contaminant your water.
i meant usng flexable type bladder or a PVC pipes inside the body not just the body to hold the water. i has anyone found any good flexible water tanks? i have been looking and looking and cant seem to find any.
like that but it loks a little hokie to me. i looked into the MSR bags and they are nice but no vent line....
Sounds like a lot of work to store a few gallons of water (yeah, I'm lazy). Honestly though, it would probably be easier to mount a stainless tank under the vehicle forward of the spare; I know there's some room there. You can buy stainless water tanks premade from marine stores or have them custom made.
i have air tanks and a storage box down there or i would love too put i under the bed. my truck is an 85 and has panels that infil the bed, i was thinking about putting the bags behind there, i dont know if the taco's have that area. and i also like my bed space.... i sleep there
what kind of truck do u have? and perhaps the tailgate can be modified to keep a small tank in it. OR use the pockets infront and/ or behind the wheel wells.
realisically there is not enough space to store a gross ammount of water. however an incab solution is behind the seats, im storing a 15 gallon tank behind the seats. simply gravity fed with a hose out the bottom. i also am mounting a hand pump on top of it.
So.....ah, why don't you just make a bladder out of animal skin.....has worked for centuries in other parts of the world, don't they even park "BOOZE" in them as well?
Talking bladders, aren't there some sort of bladders used when they ferry small planes across the big pond? Maybe a new one of them might work.
its an 85 toyota PU. and there is accutually quite a bit of room inside the "bed walls" i really like the toughness of the MSR bag. i have one that i use hikingbut they dont have a vent. i am trying to find something similar to their design that i can fit in there. i dont know if anyone has ever seen the air tanker fuel bladders but something along that design. maybe there is some way to make one but the only thing i could think of was the vacuume seaming machines for food. any ideas?
The fuel bladders are very thick- we used ones that had been removed from service to line containment tanks overseas (built wooden boxes, lined them and then put the fuel tanks in- hey you work with what ya got). Not sure what you are looking to spend, but they are generally expensive; you'd probably have to have one made in such a small size. Here's a couple links for "pillow storage bladders"
http://www.waterbladders.com/
http://www.aircraftrubber.com/
http://www.interstateproducts.com/pillow_tanks.htm
The other thing you might consider is getting in touch with MSR and seeing if they do occasional runs of larger sizes for expiditions, commercial uses etc
http://www.msrcorp.com/hydration/dromedary.asp
If all of that fails, you could probably find some sort of poly bag and put it inside of a cordura pouch and use that.
yeah i have looked into haveing custom bladders made and they are EXTREMELY expensive. i think im gonna try to run a couple of the MSR bladders and see if i can make them work. any ideas on how to vent them to refil? i will proboly use a pump to pump out.
ok so you have about the same ammount i used to, that is quite a bit of space, but i think i have an idea, it may take a little bit of work but it might work.
in boyscouts we had collapasable 5 or 6 gallon watter bags, not bladders. i will see if i can find a pic of one. they are plyable and removeable, im thinking that if the bags were removable then they would be easy to fill and shove up un there on a little shelf or something, just hook a hose to the nozzle and have a secondary nozzle to the other end.
this MIGHT work, i dont know i havent tried it.
http://www.campingstation.net/colwatcar5ga.html
http://www.bayteccontainers.com/waterbags.html?gclid=CN_No4megokCFRE9FQod_B6cLQ
MOLLYmaz
