rockandroll
Gents,
I'm headed to the land of 220 volts in the next couple months. I will need a transformer (220 to 110) and am not sure which size (watts) we'll need. I'm aware of the "Watts = Amps x Volts" equation but the 110 vs 220 vs 12 volts is throwing me off.
In 12 volt mode running off the camper battery, we don't (can't) run the camper A/C and the 3-way fridge is run off of propane. We use very little amps. I just don't know how many amps we pull when plugged into shore power (110 volts). Any help with the estimates would be helpful.
I've found [ame="http://www.amazon.com/Power-Bright-VC500W-Voltage-Transformer/dp/B000MX1QXA"]this[/ame] 500 W Power Bright transformer. But does this mean I'll get only 4.5 amps!? (500 watts / 110 volts). I'm sure we're under 15 amps (because we regularly plug into 15 amp outlets, but this would mean a 1,800 watt converter.
The AC is a Carrier Air V (I believe to be ~ 11,000 BTU). The fridge is a Dometic 3 Cu. Ft. 3-Way
