failsafefabrication
I Have a 24 volt Webasto DBW 2020 diesel fired coolant heater for sale; It has been restored and I am adding parts to it to make a complete system. For those that do not know here is a link to webasto's manual: http://www.techwebasto.com/heater_main/699540.pdf The heater is about 10 years old and has been professionaly restored, rust has been removed from all areas, repainted and all systems have been gone through both mechanically and electrically by a webasto certified technician. Pictures to follow but it will take a bit of time.
In Short The heater consumes .79L of diesel/hr on full blast and about 10A DC at 12 V or 5 A DC at 24V. In exchange it puts out 80,000 BTU of heated coolant.
This although it would be great is just too much heat for what I need in my application. I can either sell it without a circulation pump (it would be a webasto magnetic drive) and various other bits or I can fab up an entire system for a custom application, up to and including; Heater, Mag Drive pump, 12 to 24volt boost converter (samlex step 10 ) pipes, water to air and water to water heat exchangers depending on your needs.
The heater by itself would be $400 plus shipping-likely $60 as this thing weighs 38# and is 23" x 10" x 10"
Heater & Pump $550
Heater, Pump, wiring and Boost converter for 12 v $700
Basic Turnkey System: $2,000
Heater
Pump & Silicone hoses
2 coolant to air heat exchangers and fans
All Associated wiring and thermostats
PID controller; multiple set points and temperature hysteresis set points
All Associated PEX or lines of choice: 25' of hot and cold lines plus manifolds, expansion tank with insulation and drain lines.
Mounting hardware; stainless
Shipping to Continental US+ CA & Alaska: $100
Thank you.
Fail Safe Fabrication
Heater & Pump $550
Heater
Thank you.
