juha_teuvonnen
Hi All,
I am building a "truck camper" that will go on the flat bed (sides removed) of an M1083 5-ton MTV (US Army truck). I don't want to permanently attach the box to the truck and I will be using the bed that the truck came with instead. There will be an engineering solution that will deal with truck frame/bed flex and the interface between the camper box and the truck. Essentially the box will be installed on a subframe that can move relative to the bed. This way when the truck frame and bed flexes, the camper body won't break.
I have ruled out wooden and aluminum frame construction at this point because I intend to also use the vehicle on unpaved roads and in cold climate. I know about "total composites", they have a solid product which rightly commands an appropriate price. So far I was unable to find any other viable sources of panels for my build, possibly because I didn't look hard enough. I looked at various SIPs and it seems that they could be an option, but there are no extrusions/pultrusions for them that I could find. I am also not sure as to their mechanical properties, but I like the fact that theey are metal-clad on the outside and can be painted in any color. I am not big on white color. If you could tell me about vendors that I have overlooked and should be considering, I would really appreciate this information.
My other option is to build a steel outer frame (exoskeleton) and attach the panels from the inside.
P.S. Weight is not really a consideration for this build. Due to my choice of truck, I have the luxury of not being constrained by weight for this build. Anything short of brick and concrete should work.
