Photobug
Based on the numbers 100v 20a, I would guess 2000 Watts of solar but know that can't be right.
Is it 20a at 12v so 240 watts of solar?
What happens if I hook up more than that? If I were to try to use it for 300 Watts of panels, assuming less than 100% efficiency of the panels, would that be safe? If you did put too much wattage through a too small of an MPPT does it blow a fuse, or just not work to the panels potential?
