What size tires.....on an M416 ?
xcmountain80
Expo,
I need some suggestions in regard to trailer tire size. The current size is a 295/75/16 Nitto TG mounted on a Toyota FZJ80 16x8 with backspacing that works on the 4R but not on the trailer so much as they stick out a bit. Matching wheels and tire look cool but I really don’t need the 295’s on the trailer. The trailer is sprung over and allows decent ground clearance w/o a spare.
The spare on the trailer also matches the entire setup and is just plain too big to be under mounted under the trailer, though I do have a spare tire crank from a 4Runner mounted under there. I was thinking with to a 265/70/17 (have a set of Toyota wheels in 17”). The 17” wheels have more backspacing and would suck the wheels in slightly as would narrower tires, before finally fitting wider fenders.
I tow the trailer with my 4Runner most of the time but for trip where we DO NOT go off-road the Sequoia pulls it and it looks silly with the big tires. I have set up camp with both sizes and the Camping lab Trailer tent works well with either.
The question remains same size as one tow vehicle or the other 295/75/16 or 265/70/17, I’m on the verge of ruling the larger tires out and even in a 255/85 because they are cost prohibitive and offer no additional advantage.
Thank You
Aaron
COONASS
How about a 235/85/16? Relatively cost effective. Height is close to the vehicle tires. Nice and skinny.
xcmountain80
Well after a good deal of time comparing tires actual sizes on the manufactures websites I chose Kenda Klever M/T KR29 Mud Tires 255/75R17 they come in right at 32x10. They were very economical at $260 for the pair, and free shipping. I use the Kenda Klever AT on my dually work truck and they are a decent tire or the money.
I forgot to mention the 16's I have must be refinished as corrosion has taken its toll.
Aaron
xcmountain80
With 295's
With 265's
..............I have no photographic documentation of 265's on my trailer......but I did have them on there for a short trip.
Kenda Klever MT
xcmountain80
Not until I determine the finished width of the tire on the trailer. I may have forgotten to mention in this thread that the axle width ordered a few years ago may have been to wide fhan or my purposes. As the trailer sits now with the FZJ80 wheel and 295's it is about 1/4" narrower than the track of the 4Runner.
Wheels I'm using for the 255's
Aaron
xcmountain80
255 vs. 37"
rockwood
Why not get wider wheel arches and go with tires to match the truck?
I know one of the current m416 style trailer builders does those things.
Just forget who...
xcmountain80
Rockwood,
I tow the trailer with two different vehicles, a stock Sequoia and a modded 4Runner. I had matching tires and wheels, tires were getting old and dry rotten (previously on the 4R for 55k miles). So I was going for middle if the road size bigger that 31" smaller than 33".
I have talked to one if the newer M416 builders and they said the per unit cost at this time was too high. As soon as I find a metal shop with a brake that can match the ends ill just get a newer wider fender.
Aaron
jesus m anderson
