WHAT SIZE WHEELS OR OFFSET FOR WIDER STANCE?
Silverhorse
I'll be putting a Dana 60 under the front of my Express van and I want a wider more stable stance but I only want to run around a 31" or 275/65 tire. Do I need an offset wheel or would stock f350 17" wheels work ?
TIA
Johny5
The f350 rear diff is about an inch wider than the stock diff. Stock f350 wheels won't stick out much over the stock gm wheels . That's good news if you have a sliding door. If you have barn doors you can go with more off set .
At a certain point the scrub radious starts to suffer on the front a well as clearance with the body and bumper If you go too much
Mcoleman
