Background:
2016 Tacoma 3.5L
Have a dual battery kit connected via Blue Sea ACR (Off grid engineering kit), utilizing two Odyssey Group 35-PC1400 AGM batteries, and I have a third battery in the bed of the truck wired in parallel to the aux battery which is a 100aH Gel Deep Cycle battery ( https://amzn.to/2Kzcy2p ). I have a 100W windy nation panel on the roof along with their 30A solar charge controller.
I recently discovered that the Tacoma alternator doesn't charge high enough to top off AGM batteries (there is an ECU tune that will modify this). For the solar charge controller what voltage should i have it cut-off? I believe the solar charge controller defaults to stop sending power to the batteries @ 13.8V. Should I be increasing this to the 14.4 range?
Appreciate it any assistance. Just trying to get the most out of this set-up...
Thanks!
2016 Tacoma 3.5L
Thanks!
