pskhaat said:...My personal experience leads me to believe that the 91-92 FJ80s are a better expedition platform/trail rig, the engine shares many components with past generations of cruisers and are easily sourced. They are `easy' to adapt carburetors, non-US and bad-gasoline (manual dial) distributors, manual trannies and part time transfer cases to them, etc, et al. People dislike them because they are tractor engines and like all early Cruisers, not the fastest on the planet, and they can be obtained for a good price. I have a thread in here that lists all the benefits in my book of these....
cruiseroutfit said:While the 3FE (88'-92') is a great engine, it was VERY short lived and has VERY few components that interchange with the earlier 2F
pskhaat said:Engine mounts, some accessory brackets and accessories (possible), rocker cover, distributor, cam?, bellhousings, starters, even a latter model 2F shortblock can be put under the 3F-E. Not everything, no, but some good emergency parts stuff.
In my book, an FJ80 with carb'd 2F, 5spd, part time tcase would be close to perfect expedition rig (okay, maybe a 2H instead of 2F).
pskhaat said:...In my book, an FJ80 with carb'd 2F, 5spd, part time tcase would be close to perfect expedition rig (okay, maybe a 2H instead of 2F)....
cruiseroutfit said:Motor mounts are different
Ever swap out a short-block in an emergency?
Though a 2F bellhousing will bolt up to an 3FE
I am putting a 2FE setup into my 40, because I already have a 10K 2F block & a H55F
A must? depends. Like I said, if I were taking a year off to travel the Americas I'd put 'em in. You can roll start a manual tranny, not the case on an auto. You can also marginally save some gas/wear on part-time tcase.Exrunner said:you guys are saying that a 5 speed and a part time case are a must
Part-time tcases are reasonably available (from an FJ60 for instance) that go with the 4spd|5spd manual tranny. There are kits also available to make the full-time tcase in an 80 act like a part-time tcase.So how do you put in a part time tcase, or I guess, WHAT part time case do you put in?
cruiseroutfit said:built an very expedition ready 45 Series much as you described, 2H (converted to 12HT), H55F, split case, FF rear, OEM cable lockers F&R
