wheel bearings
jatibb
91 classic, after hearing and feeling a slight noise coming from the front end i decided to look and,well, bearings had welded themselves to the stub axle and all that was left was a pile of metal dust in the hub. (200+k miles, probably never lubed, rh side is ok, nice and juicy inside)
good thing i have a parts car, any way i want to replace all from bearings. i found the wheel bearing at napa, but does anyone know a generic (timken) # for the small roller bearing inside the stub axle for cv support and also a generic # for bearing seals, thanks....
I thought I saw an alternative parts list on a Canadian LR site, Attowa Land Rovers? Not sure on spelling. Or you could check on Terri-Ann's site, I have found that starting on her site usually puts an end to all the searching.
Happy hunting!
Set 37 bearings at the bearing store of the autoparts store.
X2 on the RTC3511. Not sure on the little needle bearing thingy i just swept up a dozen and tossed them?!?! Ommited with Toyota conversions.
The local bearing store should be able to figure it by dimension though.
tbnd88
