seagulljim
Gday
We have an fg649 dual cab canter 4x4 which was an ex BHP billiton hi rail service veichle and kitted out with ROPS , hiab ect.
The veichle is fitted with a 19.5 inch steel single wheel conversion with custom rims by a manufacturer in perth WA with individual serial numbers
The rear rims are 30mm inside the track of the front rims, I assume this may of been to accommodate the veichle when travelling on the rail system.
The front and rear rims are not legally interchangeable and 2 spares must be carried (you could interchange them in a pinch if you had to to get home)
The tyres are rated for the veichle load rating and are a more a truck tyre than a wide mud tyre.
The truck does not have a speedo corrector fitted and speedo is out by about 10% ( obviously one must be fitted as par the course)
I have contacted the engeneering firm for mod plate interpretations and the wheel conversion is not listed on the plate or on the rego papers.
The truck in my opinion stops as good as it should and preforms well in the sand.
What pain must I go thru to make it legal.?
All advice appreciated to australian (paticular western australian) requirements
Thank you
Thank you
