Wheel swap question? Sport vs .full size Montero
normal_dave
waytoomuchwritinginposts.
I'm sure I haven't used the right search terms, or I'm making this one harder than it is, but:
Will 2003 Montero Sport Limited factory rims fit a 2002 Montero (full size)? (offset, etc.)
Reason: I have an opportunity to pickup a spare (salvage) '03 sport limited that is the identical twin to the wife's truck, and would end up with 4 spare wheels (among other things) that could be setup with off-road tires to swap on/off the Montero.
Thanks
jeep-N-montero
The simple answer is yes, but offset may be off a tiny bit, there is a website that tells you all of the offsets for various vehicles.
plh
If I'm not mistaken, the '02 Full Size is the small diameter hub-centric wheel vs. the '03 MS having the large diameter hub-centric mounting as well as the Gen 3 have a completely different offset than the MS or previous Gens. Bolt pattern will fit, but not recommended.
