Which GPS receiver and software to use with laptop?
steve.lorimer
Hi folks
I'm leaving soon for an 18 month trip around Africa :wings: and will have a laptop mounted in the cab, which I will use for music, navigation etc.
I'm looking for help in deciding which GPS receiver to use? My assumption is that USB is the way to go, with an external antenna. Anyone have some advice for me please?
Also, what software should I use for realtime navigation?
I'm going to use the Tracks4Africa and Wanderlust GPS waypoints, which use mapsource (from Garmin).
Therefore it will be necessary to interface with mapsource.
Thanks
Steve
www.overafrica.org
gjackson
FRGS
I would recommend the Garmin 276c. It has a descent sized screen for nav while driving and you can load the T4A maps into it with a memory card. And it is USB. The battery pack sometimes causes problems, but if you run power from the vehicle that will not be an issue.
cheers
steve.lorimer
Screen not necessary
Hi Graham
Thanks for your response.
I'm not sure a screen is necessary, as I will have the laptop's screen.
What I'm looking for (I think) is just a GPS receiver which can plug into my laptop's USB socket, providing a GPS signal which software on the laptop can use to pinpoint my position on a map in realtime.
Is something like this available?
Thanks
Steve
articulate
Yes. Here's one.
I know Lance (1leglance) has used one of these, and possibly still does. At any rate, you are right, you don't need a receiver with a screen if you're going to be running software on a laptop anyway.
steve.lorimer
Software to use?
Aha! Thanks Mark! (Cool website btw)
Do you know what software Lance uses by any chance? (I'll pm him too)
Alternately, can someone recommend any software that will interface with mapsource?
Thanks
Steve
TNielson-18
