Which Polyurethane glue?
rhodos
Hi,
next time i am over in the US i have to do some work on the truck and camper, here in Germany i use Würth "Klebt und dichtet" as PU glue and sealant - i know i can get Sikka products in the States but are there other (less expensiv) recomendations?
thanks for your help.
best regards
Werner
Victorian
Wir haben deutsches Koemmerling 225 auf lager in Canada. Koennen das einfach verschicken. Gruss
Peter_n_Margaret
My DIY camper build uses 3 SIKA products to hold the fibreglass sandwich panel body together. There are almost no mechanical fixings.
Sikaflex 252 (plus the appropriate cleaner and primer) for the most structural joins.
Sikaflex 11FC for general, less structural adhesion work (sail tracks and the like).
Sikaflex Pro for lower strength and sealing applications (holding windows in and the like).
Sausages are cheaper than cartridges.
I built this vehicle 15 years ago and have never had a glue failure.
Cheers,
Peter
OKA96 motorhome
rhodos
Werner. Want to share any info on that 3 stage pop up in your avatar pic? Is it diy or manufacture built? Thanks
it a diy project - see :
jacob_lashell
