mep1811
Gentleman Adventurer
Does anyone have any experience with this wireless trailer brake system?
https://www.etrailer.com/Brake-Controller/Tekonsha/90250.html
Tekonsha Brake Controller - 90250
Proportional brake controller operates via radio frequency for simple transfer between multiple cars or trucks. Includes automatic-leveling sensor, boost feature, portable remote and continuous diagnostics. Compatible with multiplex wiring systems.
Features:
Specs:
Features:
- Brake controller activates trailer brakes in proportion to your vehicle's braking action
- Automatically adjusts trailer's braking based on deceleration of tow vehicle
- Activates immediately - no pausing like with time-delayed brake controllers
- Wireless system is perfect for shared trailers and business fleets
- Remote control lets you operate trailer-mounted power module from cab of any vehicle
- Automatic-leveling ability - internal sensor detects deceleration even if controller is not mounted flat
- Position within ± 5 degrees of level in the horizontal plane
- 3 Boost levels let you adjust initial braking power and aggressiveness
- Continuous diagnostic check alerts you to any potential problems
- Integrated safeguards protect your vehicle and trailer
- Minimizes drain on car battery when not in use
- Prevents trailer brakes from overheating by reducing power output to them during prolonged stops
- Digital display on remote is easy to read
- Manual override button is built into remote
- No hardwiring necessary for installation
- 7-Pole connector (sold separately) on trailer plugs into 7-way socket on rear of power module
- Wire lead on power module plugs into tow vehicle's 7-way connector
- Connector on your vehicle must have an active 12V (hot) lead
- Remote control plugs into standard 12V accessory outlet in cab
- Compatible with tow vehicles that have multiplex wiring systems
Specs:
- Application: trailers with up to 3 axles (6 brake assemblies)
- Power module dimensions: 10-3/4" long x 4-3/8" wide x 4" tall
- 7-Way cord length: 8'
- Measurement of horizontal mounting holes from center to center: 9-7/8"
- Measurement of vertical mounting holes from center to center: 2"
- Frequency: 3.2 GHz
- Mounting: above or on the side of your trailer's frame rail, within ± 5 degrees of level in the horizontal plane
- Warranty
- Power module: 15-year limited
- Power lead: 1-year limited
- Remote: 5-year limited
