1x1_Speed_Craig
I'm starting to think through the wiring on my trailer project (build thread in my signature below). I'll be using a 7-round pigtail, and plan(ed) on buying pre-sheathed 7-round wiring once I know exactly how long I need it. I won't have 12V power in the nose box initially, but want to eventually.
I have a few questions, though...
FWIW, I am not planning on running trailer brakes, so the Blue 12G wire will not be utilized yet.
Advice?
Thanks,
Craig
- I'd like to install LED running lights on the sides of the trailer. Given the use of running lights (vs. just taillights), it sounds like I'd want to ditch the pre-sheathed by-the-foot wiring, and run a "Y" off the tongue, and down the inside of both frame rails. For the folks using running lights, can you confirm this is what you did?
- What are you using for grommets? I found these mil-spec grommets on McMaster-Carr, and thought they'd do the trick.
- Should the grommets seal out water where the wiring passes through the frame as well, or do they just protect the wires from being cut? Obviously, I'd like to seal up the frame as much as possible (or plan on drilling drain holes in the bottom of the frame rail...not sure yet).
- I'd like to have a utility light in the bed, a back-up light (if possible), as well as leave a lead for a 12V battery charger in the box. How would you wire these? I assume the Black 10G wire will be the lead for the battery charger, and that the Yellow 14G would be used for the bed utility light. What wire do you use for the back-up light?
Advice?
Thanks,
Craig
