stevet47
I need a little wiring 101 assistance.
I have (had, read on...) a 1500w inverter that I want to control with my VOswitch (knock-off Spod). Each switched circuit on the VOswitch is rated at 30A, so I can't run the inverter power through it, I need to connect the inverter direct to the battery and simply utilize the VOswitch to turn the inverter on/off.
Here's were it went wrong... I wired the inverter direct to the battery, and thinking the VOswitch is essentially just a relay, I simply removed the integrated on/off switch from the inverter, grounded one side, and ran the other to a switched circuit on the VOswitch. The second I hooked it up, I let the smoke out of the inverter. Whoops!
Now that I think about it, I believe this was because the inverter's on/off switch gets it power from the inverter being wired to the battery; running the on/off switch through the VOswitch, I shorted something in the inverted by essentially connecting it to power twice.
Someone with more knowledge than me could fix the inverter, it still powers on, it just constantly beeps and wont put out any power. Luckily this was a 14yr old modified sine wave inverter, so this gives me a great excuse to upgrade to pure sine wave, I just need to get this wiring figured out first!
Any help would be appreciated!
PS- Luckily the VOswitch came out unscathed!
