WTB- 1st gen. 4 runner rear window motor
my rear window no longer stays up and i am pretty sure the motor is the culprit. if someone has or knows of a good one, let me know. thanks
toyotatruckjunkie
FWIW, I used an extra front side window motor I had sourced somewhere. PS if I remember. The motor appeared to be the same. Years later, I did switch the wires @ the switch to make the switch work correctly, up was down.
May be broken teeth on the gears on the regulator, not the motor itself. Believe I had that problem as well. Good luck.
Clemtiger84
