WTB - 4-6 suspension lift kit (or components) for 4wd suburban
duxndogs
WTB - 4-6 lift kit or components for 4wd suburban.
May consider leveling kit/shocks/etc.
Getting ready to purchase a 2003+ suburban so looking for suspension parts to start my build.
PM me and let me know what you have. :victory:
Thanks!!
anw7405
Its just my opinion but I would go get some ford leveling keys some Z71 coil springs with about 2" spacers for the rear. You can go 3 full inches of lift in the front without stressing anything. Get some bilstein 5100's shocks all the way around and throw on a set of 285/75 r16's (if you have 16 inch wheels). You will be able to handle a LOT with this setup and its cheap. If money is not an option get a 6" lift throw on some 35's but then you should change your gearing. $$$$$$$ on that setup. Like I said, just my opinion.
duxndogs
Thanks for the input! I may go that route...I've been looking at the Cognito leveling kits. Don't think I want to spend $$$ on gearing initially. Maybe down the rd?
I'm trying to find a 2500 4x4. Would I run into gearing issues if I ran 35's on the 3/4 suburban?
anw7405
What are you planning on doing with the suburban? If it's your daily driver and you plan on doing the occasional off roading adventure with it stick with 33's and a 2000+ burb. If you get a 3/4 ton with 4:10 gears you can safely run 35's. I ran 35's with my 1/2 ton yukon and it was just a bad idea. I run 33's on my 1/2 ton burb and they are a perfect fit.
All that being said if you are wanting a more capable off road burb go buy a 91' 3/4 ton burb. This vehicle will be much more capable off road and will easily handle big lift/ big tires. They are very cheap and easy to work on also. Just my 2 cents again.
If you have a choice and are planning on running bigger gear, always go with a 3/4 ton.
Goldenbora
