WTB: 5x10 or 6x12 Enclosed Off Road Trailer
Looking for an enclosed off-road trailer either empty, built or partially built. Ideally running independent torsion / timbren style axles.
Located in Colorado but willing to travel.
Thanks!
plh
@plh Sure, for the right setup.
I bought this a few years back, and am thinking I'd like to get something different. Probably a pickup camper. Let me know if you are interested.
Haulmark Transport 5x10 V-Nose trailer 5’8” interior height, Weight 2,100 lbs loaded wet
3500lb axle with electric brakes - setup for trailer brakes.
Tacoma Leaf Springs.
Monroe trailer shocks.
Firestone Air Bags.
Max Coupler Hitch
26 Gallon Stainless Steel Water Tank - belly mounted
Sierra 4X4 Trailer's 10” steel fenders.
Side platforms made from 1/8" steel tread plate, 1 1/2" .120 wall tubing.
Sliding Tinted RV windows in both sides.
Sliding Tinted RV window in door.
Custom Front Propane Tank Mount.
250 Watts of Solar with charge controller
100 Amp Hour AGM Battery
Atwood forced air propane furnace
Atwood 6 gallon hot water heater
A/T Overland Fast Disconnect External Shower
Exterior Shower
Fold and Tumble Bench Seat (bed)
Bi-Fold Rear Door
Rear Kitchen
Sink (hot and cold water) with drain
Fridge Slide (Edgestar 45 or ARB 47 fit, probably many others of similar size as well)
Completely insulated - R-9 foil backed rigid panel
Fantastic Fan
All LED lighting inside and out.
RV Door Lock & Latch
Crank Style Lifting Jacks on rear corners (for stabilizing / leveling)
Series 100 Toyota Land Cruiser Wheels
BF Goodrich T/A A-T Tires
So much more...
mbauerus1
