WTB 92 fuso FG front drive shaft W / joints.
sostahoe
Need a complete front drive shaft for a 1992 fuso fg.
Picked up a non-running, Abused and partially disassembled rig. Now have it running. In need of a complete front drive shaft including joints. Willing to have a front driveline built if only joints or bent unit is available. Also missing was one side locking hub assembly.
Any help on used parts or links to websites with new parts for building a new one would be appreciated.
sostahoe
Okay, I have finally found a drive shaft, but, it is damaged and could use some help in finding parts / part numbers to repair the u-joint and a missing spacer. Thought I would throw this out there to see if anybody has a reference to help me with part numbers. The double cardin joint is absolutely unrepairable and must be replaced. Also was not given the little spacer that goes between the joint and the transfer case yoke. My alternative is going to be fabbing up a complete replacement using whatever I can find from the US driveline parts supply houses.
sostahoe
Update on my search. I've been able to find part numbers from Tom's Mitsubishi in California and that's all I am able to get is the part numbers as the parts are not available. So kind of back to the original post of looking for a drive shaft. Used.
flipstick
