XLS Open Diff to Hybrid LSD Options
MrBahb
Hello all,
I'm looking into options to get the hybrid LSD into my 2002 XLS, which currently has the J34D open rear diff. It's proven very difficult to source a Touring Package's (J36D?) LSD from an XLS. I know that a few people have swapped the 4.9 gears into the 4.63 HLSD assembly for use with the 5-speed transmission, and that makes me wonder: is it possible to source the rear diff from a Limited, swap my existing 4.9 gears into that assembly and have a working solution? I don't know enough about the input gear and the number of splines to know if the Limited and XLS assemblies are directly interchangeable, so I'm hoping someone can help me figure out how to get this solved.
MrBahb
Doing some searching, I found a post a while back, here:
If you get an XLS LSD assembly, its a straight swap- no controls involved. If you get one from a LTD, you need to swap the carrier into your diff housing and have the bearing lash and tooth pattern checked.
The checking of the backlash and tooth pattern seems to imply that the tooth patterns could be different. Any ideas on whether or not the gears inside would be interchangeable?
CharlieNorth
Normally if you can not find the bolt in housing with the ratio and LSD you desire, you buy the proper size LSD that will fit your housing and swap it in. You keep your gears, both parts and swap the new to you LSD into where your open diff was. You generally need to purchase the shim set for the side gears to do the job right.
Nothing more than that.
Michael Brown
You followed me, so now we're both lost
For Gen 3, it is preferable to locate a complete differential with the LSD. They were made in 4.9 for XLS/4-spd and 4.3 for Limited/5-spd. I do not know if other gear ratios fit in the housings.
If you find a labeled 01-02 XLS "Hyblid" Diff, it will bolt in place of your current one with no gear swap necessary.
plh
I have a Gen 3 LSD available. Just the LSD, no gears, no external housing. Let me know if you are interested in it.
jesus m anderson
