Yaesu FTM-10R: The waterproof Dual Band HAM?
Beowulf
Does anyone have any experience with this unit from Yaesu?
WORLD’S FIRST DUAL-BAND MOBILE DESIGNED TO SUPPORT ALL-WEATHER OUTDOOR MOTORSPORT ACTIVITIES
COMPLETE NEW STYLING EASY-TO-OPERATE PACKAGE
The exciting newly designed FTM-10R/E* Mobile 2m/70cm Transceiver is packed with innovative features that operators have been dreaming of for years. Great new appearance with keys and indicators that are illuminated with very bright LEDs. The bright ocean blue negative type LCD display is easy on your eyes.
Super compact detachable front panel is ready to go with your motor vehicle! The unique Waterproof/Dustproof Front Operation Panel is designed to support All-Weather Outdoor Activity in a manner never before possible. Detach the front panel with one-touch release when transmitting! The detachable front panel may be separated from the main chassis, and attached to a flat metal surface with the magnetic mounting bracket. The microphone and PTT button are built into the front panel.
This front panel meets the IP57 standard - waterproof at 3 ft (1 m) for 30 minutes and protection against dust – making the FTM-10R/E* the perfect outdoor communications and entertainment package.
NB: Use of a communication device with a display while driving may be prohibited in some states and some countries.
*European Model
Rugged Construction - take the FTM-10R/E where the action is!
The main body of the FTM-10R/E is a solid die-cast aluminum sandwich structure. The high quality die-cast aluminum chassis doubles as the heat sink providing more than enough air-cooled ventilation for the power modules. The sandwich structure also provides far better resistance to vibration and shock than many conventional transceivers and radios. The design shields against ignition noise and alternator whine for mobile operation! *The FTM-10R/E die-cast chassis section is not a waterproof structure
Compact and Light Weight
Size: 4.4”W x 1.5”H x 7.0”D. Weight: 2.9 pounds.
Heavy Duty Yet Easy to Operate...Even with Gloves!
Heavy Duty Yet Easy to Operate -- Large Multi-function dial & durable keys that are easy to operate...even when wearing gloves. A minimum number of key buttons on the front control panel, for safer operation during motor sports activities.
Plenty of RF Reliable Power Output
Plenty of RF Power Output – 50W on 2m / 40W on 70cm. The high power RF output of the FTM-10R/E is produced by the heavy duty, high efficiency, RF POWER MOS FET amplifier. Powerful and reliable 2 m / 70 cm Band operation is guaranteed. *Power Requirement: 13.8 VDC from external source
Industry 1st - Detachable waterproof front panel
Industry 1st - Waterproof/Dustproof* detachable Front Operation Panel to Support All-Weather Outdoor Activity. A high quality 1.1 inch/28 mm speaker is built into the FTM-10R/E detachable front panel; you can operate it like an HT! The microphone and PTT button are built into the front panel. Detach the front panel with one-touch release when transmitting! The detachable front panel may be separated from the main chassis, and attached to a flat metal surface with the magnetic mounting bracket. Incredibly versatile vehicle mounting options. The detachable Front Control can even be mounted on a motorcycle handlebar using the optional MMB-M11 multi-angle bracket. *Meets the IP57 standard. Waterproof at 3ft (1m) for 30 minutes and protection against dust. *The FTM-10R/E die-cast Main Body chassis section is NOT a waterproof structure
Industry 1st - AF Dual Monitor function..also connect your IPod!
AF Dual Monitor Function: Listen to your favorite AM or FM stereo broadcast station, and monitor an amateur band at the same time. Note: AF Dual Monitor Function does NOT permit monitoring two different amateur bands at the same time. **External audio input is also available to connect your iPod!**
Industry 1st - Intercom to communicate with fellow passengers
Industry 1st - Intercom feature to communicate with fellow passengers
Industry 1st - Automatic Volume Control
Industry 1st - Automatic Volume Control to adjusts the speaker volume relative to nearby noisy environments
Industry 1st - Receive and Transmit Text Messages
Industry 1st - Text Messages
The message function can transmit alphanumeric messages (up to 20 messages/16 characters maximum) with a sender's ID. In an emergency the message can be communicate...even in noisy outdoor environments
Industry 1st - Unique Delay VOX function
Industry 1st - Unique Delay VOX function – automatic audio delay on transmit to insure transmission of all words
Industry 1st - Bluetooth accessories!
Industry 1st - Bluetooth accessories coming soon!
Independent AM/FM broadcast receiver
The FTM-10R/E has a completely independent AM/FM broadcast radio receiver, in addition to the amateur band receiver. You will enjoy broadcast band receiver coverage, and high quality operation on the 2 m / 70 cm Amateur Radio bands at the same time.
High power 8-watt PA communications with optional speaker
A high quality 1.1 inch/28 mm speaker is built into the FTM-10R/E detachable front panel; you can operate it like an HT! The FTM-10R/E has a large 2 inch/50 mm, 1.5W speaker in the die-cast Main body chassis. The radio is equipped with a high power 8-watt audio amplifier, and a PA function for noisy outdoor environment operation with the optional, moisture and dust protected MLS-200-M10 external loudspeaker(s). **External audio input is also available to connect your iPod!**
Smart Key on front panel for quick access to most important functions
Smart Key on front panel to access the most frequently used radio functions. The Smart Key features: DIMMER- Adjust brightness of the display. INTERCOM- Turn Intercom function On/Off. MONI- Disables the noise squelch to hear weak signals. PA- Enables/Disables the PA function. SCAN- Scan frequencies or memory channels. SQL LEVEL- Adjust the squelch threshold level. SSCH- Activate Smart Search function. TX POWER- Select the transmitter power level. VOL.ITCOM- Adjust the intercom audio level.
Club Channel Monitor
Club Channel Monitor – always monitor a designated user-defined frequency
Smart Search
Smart Search – scans and loads frequencies automatically where activity is found
500 Channel Band Group Memory System
The versatile memory system uses up to 500 memory channels. Each memory channel can be labeled with an 8-digit alphanumeric tag. The memory channels may be recalled by a specific operating band, if desired.
Automatic Range Transponder System
The ARTS (Automatic Range Transponder System) feature provides audio and/or visual confirmation that another ARTS equipped station is within communication range.
Event Timer Stopwatch
The FTM-10R/E includes an Event Timer Stopwatch with an interval function to support many outdoor motor sports activities.
Wireless Cloning
Wireless cloning allows transfer of memory information without a cable.
Time-out Timer
The Time-Out Timer (TOT) function can end a continuous transmission after a preset time
* Other Useful Features *
OTHER USEFUL FEATURES
-DC input voltage display
-Tone control
-Band Up/Down key for easy operation
-Simple key lockingAutomatic
-Display brightness control
-Three transmit power levels: 50W (70cm: 40W) / 20W /5W
-Various scanning features
-The Internet Connection Feature can be used to access the Vertex Standard WiRES-II system
Model Description
FTM-10R A2 PKG-1 FTM-10R A2 PKG-1
Model
Brackets
MMB-M10
Multi-angle Mounting Bracket
MMB-M11
Handle Bar Bracket for Motorcycle
Cables
CT-M10
Separation Cable - 20 feet/6 meter Front Panel separation cable
Note: 10 feet/3meter Front Panel Separation Cable is included as a supplied accessory
CT-M11
External Headset Connection Cable - for connection to after-market headset
Microphones
MEK-M10
Microphone Jack for FTM-10R
Required to connect a microphone to the front of FTM-10R detachable Front Panel unit. Connection to the rear of Main Body does not require this accessory
MH-68A6J
DTMF Microphone
When used with FTM-10R:
* Connects to rear of Main Body without additional accessories
* Connection to front of Front Panel requires the addition of accessory MEK-M10 microphone jack
MH-68B6J
Normal Microphone
Power Supplies
FP-1030A 30A Power Supply 110V [Click to view larger image]
Speakers
MLS-200-M10
Speaker - Waterproof (Equivalent to the IP55 Standard)
External speaker (8 W)
Monoral Output
Amateur Radio \ Brochures
FTM-10R/E Specifications ( 32.24 KB )
Amateur Radio \ Brochures \ VHF/UHF Mobile Transceivers
FTM-10R/E Images ( 1.57 MB )
FTM-10R/E Images-Devices ( 1.95 MB )
FTM-10R Brochure ( 472.37 KB )
Amateur Radio \ Manuals \ VHF/UHF Mobile Transceivers
CT-M11 Connection Cable Manual ( 485.18 KB )
FTM-10R Operation Manual ( 5.35 MB )
FTM-10SR Operation Manual ( 4.81 MB )
FTM-10R/10SR Quick Code Sheet 1/31/08 ( 103.37 KB )
iStan814
