I will be installing yakima tracks on my snug top I just bought and have a couple questions. I'm a little paranoid about my truck and want to make sure things work as perfectly as they can. This will be supporting my CVT RTT.
1. I bought a reinforced topper which has a honeycomb section in the middle providing reinforcing. I have heard to put the bolts for the track through this part, and I have heard the opposite. I called SnugTop twice and got two different answers. Any thoughts/experiences with one way or the other? I want to make sure my load rating stays intact, but don't want to crush the reinforced part while tightening bolts.
2. Second question is about the size of track that would match up with a short bed shell. I have about 48" of useable area, and tracks come in 42, 54 and 60. I want to make sure there is a bolt hole at the end so I don't have one end of the tracks sticking up. What size did anyone with this set-up use? Depending on the pre-drilled hold spacing I'm guessing I could cut a 60 down and be close? I'd rather do that then buy the 42 and be short on distributing the load.
Really anxious to get going on this so I can mount my RTT again (had a bed rack before). Any help would be greatly appreciated!
Colton
Colton
