Yellow flame on partner stove
Scoutman
Using our stove this weekend I noticed that my left burner wasn't burning the efficient blue flame it should. Anyone run into this and what was the fix? I assume something needs cleaning but haven't pulled it back out to check.
Sent from my XT1585 using Tapatalk
KK6POV
It doesn't seem to be getting enough oxygen, clean it or check that the air inlet isnt clogged with food or something
Scoutman
I didn't get a chance to check it this weekend but I'll brush off the soot, blow out the burner with compressed air and see if there's a change.
Scoutman
Knocked this one out the other weekend. I'm still not 100% sure what the 'trash' ended up being but bottom line is I took a small stainless steel wire brush to the burner making sure all the holes were open and soot were gone and also used some compressed air to blow everything out really good. Seemed to clear things up.
Rivers2run
They have a field repair kit there is a way to clean the jet. Call Partner Steel and they'll tell you exactly how to do it. No phone tree you talk with one of the guy who builds the stoves.
1reddog48
