projected
Zamp Portable 120 Watt Solar Panels w/ 5 Stage Digital Deluxe 10 Amp Solar Charge Controller - $550 - Located in Denver
Like new, purchased new July 2018 and only used a few times prior to our Yamaha EF1000IS (Which is also for sale) purchase that same month.
Here it is on Amazon: CLICK HERE
Comes with a very nice carry case. This panel is awesome, I can literally set it up or break it down in about 3 minutes. The 5 stage controller allows you to choose what type of battery you are charging and gives lots of good info while it's charging.
Manufacturer Info:
Our 120 Watt Portable Solar Charging System is our most popular portable. 120 Watts works well for a wide variety of campers in many locations. In bright sunny locations 120 watts can be enough to put back BIG POWER into the battery. For light to medium energy users 120 watts can deliver the power needed for low light, cloudy situations or when days are short.
The Zamp Solar 120 Watt Portable Solar Charging System features our 10 Amp solar charge controller mounted on our EZ-View swinging bracket. The EZ-View Bracket allows the user to stand while viewing the digital deluxe solar charge controller. The Zamp Solar Digital Deluxe 10 Amp Solar Charge Controller is a 5 stage, weatherproof, PWM solar charge controller. A large digital display shows the user battery voltage, an instant view of amps from the solar panel and how many amps charged the battery over the period of time it was connected. 3 indicator lights show – Faults (any errors) | Charging (solar is charging the battery) | Full (battery is full and solar is maintaining).
This 120 watt Portable Solar Charging kit provides 6.84 amps of charging power per hour under optimal sun conditions. Depending on where you live and what time of year will depend on how many hours of optimal sunlight you can expect to receive. Typically we use an average of 6 or 7 hours for the summer and 4 to 5 hours for the winter. Commonly these figures are lower than expected.
Great for small travel trailers, truck campers, camper vans and single or dual battery systems.
Some Specs:
33 lbs
Open Dimension 41" x 35“ x 1.5”
Closed Dimension 21" x 35“ x 3”
120-Watt Power Output
Generates 6.84 amps
25-Year output warranty
Weather Proof Controller
4 Adjustable Battery Type Settings
Digital Display Shows Volts, Amps and Accumulated Amp Hours for the Day
Estimated daily amperage – 48 to 54 amps (summer), or 27-34 amps (winter)
Please PM with any questions, thanks for looking!
Manufacturer Info:
Some Specs:
33 lbs
Generates 6.84 amps
