I have had a Hot Camp for several years and although I love the heat unit the battery pack and pump are not on my favorites list. So I have over the years performed some mods. First the plastic hose melts easily at the heat coil if you make the mistake of not having the water running all the time. I replaced the hose with rubber fuel hose and 90 degree connectors and quick release fittings. The plastic hose also crimps where it came off the heater when stored in the box.
Then I was went looking for a 12volt pump system. I have a battery in my trailer or the Jeep so I tossed the D Cell unit and bought a Primus pump and shower head. I cut hoses and fixed it to work with the quick connects and now it plugs into a 12v volt cig lighter or anderson power poles.
I have been using that setup for quite awhile but I wanted more pressure at the shower head so I found an 12v inline bilge pump from Rule il200p.
I installed a 1/2 to 3/8 reducer and Anderson Plugs.
Now here is the whole setup.
