SOLD '06 Sportsmobile 4x4 (Ford E350 EB diesel) - SOLD
BroncoHauler
I've been asked some questions about some of the configuration options, so I'm attaching some new pics.
Shorter rear bed platform
attachment.php
attachment.php
Taller rear bed platform
attachment.php
attachment.php
Rear bench seat
attachment.php
Penthouse bed
attachment.php
With the front-most Captains seat removed
attachment.php
With the front-most Captains seat installed
attachment.php
The Sportsmobile also comes with three extra, identical Captains chairs. One used to go where the galley unit now sits, and two used to go where the rear bench now goes. The Captains chairs and the bench utilize different mounting brakcets so they are not interchangeable. Also the rear bench headroom isn't the greatest, so I wouldn't recommend for people over 5'7"-5'8".
Herb
BroncoHauler
Had a few questions that have come up a few times, so I thought I'd answer them here and in my ad on SportsmobileForum.
1) Yes, I monitor EGTs. The BD Power X Monitor displays EGTs, Trans temps and Boost. The pyrometer is pre-turbo, and the alarm feature of the X-Monitor is set to 1300 degrees. I drive by the EGTs and never let them go above 1150 or so, and try to keep them below 1100 at all times.
My ideal EGTs before turning off the engine are 350 degrees, my goal is 375 degrees, and I NEVER shut off the engine until the EGTs are below 400 degrees.
2) Yes the SMB has a Hi Idle feature. The transmission must be in Park, with the parking brake engaged to operate the hi idle (also known as auxiliary idle) which raises the RPMs to somewhere around 1200 rpm. Useful if running the compressor for extended periods of time.
Hope this answers some people's questions.
FYI, I also religiously monitor trans temps, and have never had anything approaching high temps. No doubt the MagHytec transmission pan with Amsoil synthetic transmission fluid helps in this regard. I also monitor engine oil temps and engine water temps on my ScanGauge. Monitoring the differential between these two readings let me know earlier this year that I had a problem with the oil cooler before there was any failure. This led me to have the oil cooler replaced, and I also had the factory EGR Cooler replaced with a unit from BulletProof Diesel at that time.
Herb
BroncoHauler
Asking $72K
Thanks Brett. Yes, I updated my first post with the new asking price of $72K. I should have included that in the bump where I mentioned the lowered price.
This would make a nice red sleigh for the holidays. No reindeer needed.
Herb
Logans91XJ
Dirt Road Anthem
my apologies that I am posting here and I have no interest in your AMAZING RIG well if had 72 grand I would be happy to own this. I just wanted to say good luck with this sale and whoever owns this will have one the of sweetest Expo Rigs I have seen hands down! This looks soo freaking sweet. Damn I would take this camping in my driveway or better yet just live out of this.
Herb Nice Job on this build.
BroncoHauler
Thanks for the kind words!
Herb
BroncoHauler
Yep, still for sale.
A few nibbles in the past few weeks, so we'll see if any of those pan out. I knew it would take a while to sell this rig in this economy. If it doesn't sell, I'm more than happy to keep it and enjoy it.
Herb
BroncoHauler
Had a question on the seatbelt situation for the middle and rear Captains seats. The Captains seats have the seatbelt mechanism attached to the seat itself, with the shouldbelt attachment point connected to the van body. The second pic shows the anchor point for the shoulder portion of the belt. That part always stays connected unless removing the Captains seat.
To remove the Captains seats, the shoulderbelt is disconnected, and the seat pedestals have a quick disconnect that is moved, and then the Captains seat are removed.
Herb
BroncoHauler
I had someone interested in the SMB wanting me to confirm that the Captains seats (not the driver's or front passenger's) can rotate. I removed the one bolt, and after disconnecting where the shoulder belt attaches to the van body, and after releasing the latch, the Captains seats do rotate. When rotated back to the forward position, the seat locks back in place.
The available room for the two rear-most Captains seats to rotate is limited if the rear bed platform is installed however.
Herb
BroncoHauler
Was hard to see it drive off, but the new family should get lots of joy out of it, based on theirs smiles as they drove off.
Herb
Clemtiger84
