RMP&Os 1977 Patrol Ute build for overlanding
4Rescue
ANd here I was just using a funny phrase... HAHAHAHA If you were concieved in Oregon you were concieved in wet weather aye ;)
Yeah really intersting about the auction... leave it the govenment to make you technicaly RE-BUY your own truck or at least put it up for arbitrary sale to keep it... so strange. However it's great you're getting titles. I just heard about a really absurd and kind of related law in Oregon that states that it is ILLEGAL to have an unliscenced vehicle on your property... Splain that one to me :???:
Cheers
Dave
RMP&O
Yeah Kurt, I have heard Utah is one of if not the easiest state in the nation to title a truck.
And that is a strange law in Oregon. Especially since everything grows so much there, ie got blackberry bushes much!? I bought some Patrol parts years ago from a guy down in Grants Pass. He had found this old 1962 soft top Patrol buried under 5 acres of blackberry brush. The owner had owned the property for nearly 20yrs and had no idea the Patrol was there so he gave it to the guy who found it. The guy had been hired to clear the brush. There has got to be many more cars out there in Oregon hiding under brush. So it is odd that such a law would exist.
4Rescue
That's an awesome story/background on where the Ute came from aye... Gotta love good ol NW blackberry patches. I've got one protecting the bare lot at the back of my property from becoming a highway for the loacl homeless guys to go through from the park to wherever through my yard... I'm keeping the blackberry's ;)
Can't wait to see more of what happens to this rig. If it's anything like all the other trucks I've seen of yours it'll be sweet as aye.
Cheers
Dave
RMP&O
The Ute now has a legal USA title!! This goes to show you can import a truck and have no title and do everything the legal way and still get the truck legal, titled and ready to use on USA roads!
I took me 7yrs to get it titled, actually only a couple months once I worked on it but it is a big relief to finally have a legal title for this truck. Oh and the vin # on the title is all of 5 numbers!! :)
Abitibi
Congrats, good to have all your documents sorted out and even better how you're building your truck!
I guess your Patrol could be the grandfather's of mine... ;-)
I just noticed the Patrol forum under your signature, time for a visit!
Keep the post coming, she's a sweet rig!
Cheers
Mr. D
RMP&O
Got it all figured out on what I need for suspension brackets. I can buy everything from RuffStuff. Plan to do a cut & turn on the front axle to set castor and pinion angle. All I need now is the cash for all the perches, brackets, tabs, ect!
Some more pictures of gear I have for the Ute....
fuel cell, perfect for bed mount.
main.php
The big Safari Tuff clutch
main.php
The Yuri high steer and big H233 "strengthened" CVs.
main.php
top knuckle trunion bearing is modified, so whole new knuckle was supplied with the high steer kit. As you can see it is double sheer, the high steer arm is also "keyed". Bling bling! ;)
main.php
RMP&O
I have a vintage 1980s ARB style bull bar. If it looks decent on the Ute I am thinking about customizing the mounting brackets so it will fit the Ute and then use it on the truck.
Last bit of info....I pulled the motor and the rear axle out of the Ute not to long ago. I swapped in a rear axle that was originally in my 83 Patrol along with the leaf springs. Just so I can keep wheels on the truck and move it around easily.
Here is a picture from when I pulled the engine & gear boxes out of the Ute a few months ago....
and the axle...
main.php
main.php
main.php
RMP&O
Here are some pictures and links....
The new (old & used) firewall/dash I have for the Ute. This is from a 1965 USA Patrol so it is LHD and allows me to convert the Ute from RHD to LHD. This will be the first body piece I work on.
main.php
Here you can see some rot in the kick vent area, very common on old Patrols.
main.php
main.php
The rest of the firewall is in very good condition. So I will either work this rotten section on my own and fab patch panels or buy these new patch panels....
main.php
This is a bigger patch panel which incudes the pillar. This is what I will likely use since the pillar on the 65's firewall is a bit rough.
main.php
The Utes fenders are pretty rough too, they definately have some body filler on top of rot. If possible I will save them with repair work to fix up, if they are to far gone I will simply buy these....
main.php
The windshield frame on the Ute now is pretty much history. It has got some deep rooted rot which will be very hard to fix. So more then likely I will replace it with a new one....
main.php
main.php
The last bit of rot to deal with is on the top of the Ute. It also has some deep rooted rot which is going to be the hardest to fix. However, I do have a 1965 USA Patrol hard top. My plan was to simply cut it up, weld it to the Utes top and use as much of it as possible and then simply patch what I couldn't fix using the 65s top. Here are some pictures of the rot in the top that needs to be dealt with.
main.php
main.php
main.php
main.php
This is definately going to be the hardest rot to fix. However as mentioned I got a rot free top form a 65 to work with. Also as you may note most of the body is flat and straight, from the factory with box tube and so forth. So those parts won't be to hard to replicate or make patch panels for, especially if you had a sheet metal brake. The rounded or curved parts in the rear will be the toughest to fabricate patch panels for.
I don't have a very good picture of the Utes hood right now but in this picture you can see the P/O's mount on the hood for carrying a tire like a Land Rover. For this mount the P/O cut a big huge hole in the center of the hood. So I picked up this decent hood from a 65 to replace it.
Here are the best picture I have of the Ute's hood for now.....
main.php
and the replacement hood I picked up for it....
main.php
main.php
main.php
The 65s hood is not perfect by any means, it sat under a walnut tree or similar for years. So it has a bunch of small dimple dents in it. However, the hood from the 65 is rot free and fairly straight so I will be using it.
I will buy the suspension brackets and whatever else I need from either Synergy or RuffStuff. A few things I imagine I will be fabbing myself such as cross members.
Synergy fab parts....
http://www.synergysuspension.com/Brackets-Tabs-Trusses-p-1-c-4322.html
and the RuffStuff fab parts....
http://www.ruffstuffspecialties.com/catalog/34linkbracketslinktabs.html
I won't be buying any of the suspension stuff in kit form because I will be building my own SOA suspension.
cheers! :)
RMP&O
Here are some more pictures of the axles. Ignore the suspension set up. :rolleyes:
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
main.php
I also plan to run the PTO winch, you can see the PTO box and shafts on the RHS of the picture. A flat belly skid plate like this will also be used on the Ute.
main.php
main.php
main.php
main.php
cheers
RMP&O
You have some rad vehicles! This ute is going to be somethin!
Thanks!
I just may have found my next vehicle....a mid-1980s Subrau!! It is only $300, need to check it out still. If I sell my Cruiser I am buying it for an around town/valley car. ;)
RMP&O
Bumping this because....
I edited all of my posts. The Ute and what I am doing with it has changed for me. Plus no posts here since early January!
RMP&O
Just bought everything tonight to SOA the Ute with the axles pictured above. Spring perches, leaf hangers, shackle hangers, shackles, u-bolt plates, u-bolts, shock tabs and I have a set of Ford shock towers for the front. I didn't buy the shocks or the stabilizer but otherwise got it all.
I purchased it all from RuffStuff, I like doing business with Dan.
Smudge12
