mvbeggs
Mvbeggs,
I spend half the year or more traveling, mostly the western states. I'm familiar with virtually all the rocky mountain grades. My trailer weighs 2350 on the axle with 225 on the tongue for a combined truck load of around 600 pounds with gear. I have the 4.56 gears with 235/85-16 E rated tires (approx 32"). My unloaded truck weight is 5350 with a full tank, me and 2 dogs. I also towed this combination with stock gears prior to the switch. At 65 I'm turning 2550 RPM in high gear (manual 6 spd). With the 255s you would need the 4.88 gears to approximately match what I have....<snip>
Hope that helps....
That is EXACTLY the kind of information I need. Thank you for the in depth, response. Your entire response really gives me something to sink my teeth into.
....At 65 I'm turning 2550 RPM in high gear (manual 6 spd). With the 255s you would need the 4.88 gears to approximately match what I have....
I may have to live with some downshifting on the steep grades. (After gearing and tires, it looks like 4th gear in the auto, 1.00 tranny gear ratio, would put me at about 62mph at 2550 rpm.) I'm concerned the 4.56 or 4.88 gearing would kill me, and the gas mileage, coming across the flats of Kansas and Colorado at 80mph. What kind of gas mileage are you getting in your access cab? One of my main goals for a Tacoma build is to increase my range over the Jeep's.
....There is one issue though that is probably not common knowledge. The weak link in the towing ability of the 4.0s is the rear diff. Both the 8" and the so called "8.4" measure 8". That is a really marginal gear size for the power of the 4.0 under high loads. When I swapped gears after just 20K of combined towing my carrier bearings were already showing evidence of spinning....
Good to know. I wouldn't have thought that about the rear diff. Too bad they don't build the Tacoma as stout as they build the Tundra. Great intel on the operating temps in the rear diff. So, am I correct in guessing, you wouldn't recomend supercharging the 4.0 in fear of totally annihilating the rear diff? :ylsmoke:
