p1michaud
To the ExPo LandCruiser enthusiasts, a question I have for you! What option would you choose if you had the option between the following:
Additional information:
80 Series
Full history of the HZJ80R DX model 80 Series is known, meticulous and up to date maintenance, all the fruit (bumpers, long range fuel tanks, water tank, winch, etc…
and ready for an expedition. It's a manual and part time 4WD as well for those who may not be aware.
Toyota 1HD-FT 4.2L factory turbo diesel engine with 24 valves that was a factory offering in the 80 Series. Power: 125 Kw (168 Hp) Torque: 380 N-m (280 ft-lb). Claimed figures after 3” exhaust, intercooler and dynotune: Power: 163 Kw (219 Hp) Torque: 470 N-m (347 ft-lb).
Toyota 1HD-FTE 4.2L factory turbo diesel engine with 24 valves, introduction of more electronics (i.e. more advance version of 1HD-FT above) and intercooled on the 100 Series engines. This engine was a factory offering in the 100 Series. Power: 151 Kw (202 Hp) Torque: 430 N-m (317 ft-lb). Claimed figures after 3” exhaust, performance chip and dynotune: Power: 176 Kw (236 Hp) Torque: 528 N-m ( 389 ft-lb).
Pros:
Known vehicle history
Solid axles front and rear
Full floating axles (bush repair friendly, i.e. remove broken axle to get to next destination).
Cons:
15 year old vehicle
Funds for engine conversion would not be recoverable on sale of vehicle.
100 Series
The 100 Series will most likely not be modified but may have some aftermarket accessories fitted at time of purchase. May or may not have full history of the vehicle.
Pros
More confortable than the 80 and would lead to less driver fatigue on longer drives.
Much better power and torque
Better fuel economy.
Better resale value
Updated safety features (dual air bag, anti lock brakes, full time 4wd)
Cons
Semi floating rear axle (less bush repair friendly).
IFS lower A-arm weakness (can be rectified via a proper lift and strengthening kit).
Weak front diff (can be rectified)
Larger than the 80 Series
I've been thinking about both options for some time now since we have been towing a camper trailer on our adventures. It comes down to the 1HZ not having enough power and torque to safely tow the trailer (speed limit is about 90 Km/h and don't even think about passing).
I ‘ve re-read this article: Top 10 Used Overland Vehicles and it got me thinking about the 100 series. I'd been doing quite a bit of research on engine conversions. The two possibilities I'm willing to consider are listed above (i.e. 1HD-FT and 1HD-FTE)
My only hesitation is that from my test drives (limited to on road unfortunately) I get the feeling that the 100 Series lacks the robustness of the 80 Series. I'd like to get a bit of input from those who have a 100 Series and use them off road. Is this just my perception that the 100 Series is not as robust?
I suppose that a bit of a tease is warranted here as well. We did test drive a 70 Series LandCruiser, a GXL wagon (VDJ76R) with the nice new V8 turbo diesel and all the off road goodies but decided against it in favor of the 80 and 100 Series but that's a whole other story… :costumed-smiley-007
Here's a photo of the cruiser we took for a spin:
So what say you?
- Engine conversion on a 1997 1HZ 80 Series with 218000 Km on the vehicle. Engines being considered are the Toyota 1HD-FT (factory offering in the 80 Series) or 1HD-FTE (factory offering in the 100 Series) more on this below.
- Upgrade to HDJ100R (100 Series Turbo Diesel)?
80 Series
Pros:
Cons:
15 year old vehicle
100 Series
Pros
Better resale value
Cons
So what say you?
