New Goal Zero Power Pack for Overlanding
coachmen96
Thanks, I have a situation where I will have a 12 volt outlet while driving but no access to battery while stopped. So I am trying to put together a portable powerpack for this fridge.
Corey
OverCamping Specialist
Can you just hardwire your 12v outlet to a Bluesea aux. box?
That is what I did in the back of my FJ where the stock 110v converter is.
A friend and I added two Radio Shack 12v outlets, wired them to a Bluesea aux box in the passenger footwell, then the box to the main battery fused.
And now when I am parked while camping, the Powerfilm 60 watt panel recharges the main battery.
I also have the adapter cable that was made for me by the vendor I bought my Goal Zero stuff from to mate the Powerfilm solar panel to the 350 battery to keep it charged up too.
Butch1979
Family Adventurer
Did anybody ever pickup one of the Extreme 350s and see how long they would run a fridge? I'm thinking of using a Goal Zero 350 Kit to run some basic lights and such around my expo trailer and would like it to also run the fridge. If I wanted to "beef up" the system should I buy another 350 battery or an additional 30 watt solar panel?
mattm01
I've been waiting for the temps to pick up a bit here (TX) so I had a more realistic setting. I'll see what I can do this week test wise...
mattm01
So a quick and dirty test: waeco cf50, Pre chilled to 33 on AC, 60% full with beer bottles, garage temp was ~73 degrees on ave for test. 13 hrs on the Extreme 350 pulled 80Whrs with me occasionally opening the lid for more "realism".
I'll do a better test when I have time
There are much more detailed posts on fridge power draws out there. I used some google foo to find them. Don't have the links right now.
Butch1979
Family Adventurer
Nice! Thanks for the update. So for 24hrs (or indefinite) you would need 2 batteries and the solar panel.
mmcan
I have and highly recommend this set-up,...
http://www.goalzero.com/shop/p/66/Extreme-350-Base-Camp-Kit/1:3/
Got it at a very good price through BlueKangaroos.com
GREAT customer service from Justin, and the system is sweet. Not the cheapest, but it's a nice clean functional package that works. Open the box. Plug in to charge. Run items off the battery and relax.
I will definitely get the Yeti once it's available. According to GZ as of today, the Yeti will be here late spring/early summer.
mattm01
Sorry, that post was from my phone so it was a bit incomplete. That was running JUST off the battery. No Solar anything. At that rate (~ 80 W Hrs / 12 hrs) you'd burn up 160 Whrs in a 24 hr period with NO SOLAR. The Extreme 350 is rated at 350 Whrs so you're just about at 50% (which is about as far as you want to go to preserve battery life. You can go lower, but the lifespan of the battery will suffer). You'll want some sort of solar to replenish.
Ghostship
I love GoalZero products, I use the Guide 10 Adventure Kit for kayak expeditions/backpacking. Be aware that their large kits are rated in Watt-hours, as opposed to Amp-hours. So the Extreme Basecamp 350 at 700 WHrs is equivalent to 58 AHrs, which is a little more that half the capacity of a Sears Diehard Platinum Marine Group-31 AGM battery (on sale right now for $252). In addition to a total 58AHrs of battery, you get 120 total Watts of solar panels, a 400W modified (not pure) sinewave inverter, and 4 3-Watt lights...for a retail price of $2120.
You could put together two Group-31's, a ~150W solar panel, a charge controller, a 2000W modified sinewave inverter, some lights and necessary wiring for $2400. This will give you 2400 Watt hours battery storage compared to 700, 20 more Watts per hour of solar charging, and an inverter that will allow the use of power tools and cappuccino machines. Even just one Group-31, a 120W panel, charge controller and ~400Watt inverter will give you more capacity for about a grand.
Then again, I have over $4000 invested in 4 Group-31's, a 175W panel, 400W wind turbine, 2000W Magnum pure sinewave inverter, charge controller, and enough copper wire to make crackheads drool. So whatever works for you.
Butch1979
Family Adventurer
I think I'm going to grab a Group 31 and give this a shot... I already have a 60W solar panel ordered, so I'm going to attempt to build one.
Fireman78
I recently had a power outage at my house overnight. We plugged in my Extreme 350 and ran the 50qt ARB all night long. Also ran a light for a while too. Only one bar was gone on the charge indicator in the morning. (The 350 would NOT power my full size fridge.) I am pretty impressed how fast we were able recharge the pack with one Boulder 30 panel the next day.
Xterabl
Until the next Chinese revolution, everything solar will continue to get cheaper and cheaper (probably have 2-3 years to go; which means 20-30% price reductions from current). Goal-0-$-Left-In-Your-Pocket is pretty much highway robbery for their basic lower end products. Probably 20-50 $ / watt, I guess when going rate for THE SAME CHINES MANUFACTURED CELLS is 5 -10 $/W. Anything connection related can be fixed with basic grade school cutter-stripper-wire nuts knowledge (unless you were never allowed in dad's garage, I guess). Seriously, how can you talk about compatibility issues when you're dealing with a plus and a minus wire (anyone ever done a smidgeon of home AC wiring? Installed a fancy chandelier for the wife??? I mean, wow!, there's even a 3rd wire for that crazy stuff!!!). Seriously, if you're into solar, go buy yourself a $10 DC wiring book and spend 2 hours reading it. Then go browse Ebay and your local hardware store and you can save yourself a half grand or more by making your own. But then, is it worth puking every time you see a Goal-0-Value-Added scam product at your local Lowe's home improvement center???
No offense intended to the folk at Goal 0...but until they explain somewhere why their prices are so high I have to call out this kind of fraud.
JMHO, dudes.
iStan814
