I am not familiar with the diesel engines in these but it could have something to do with the oil or filter used. Where'd you get the oil changed at? Was there anything else done other than an oil change? They may have checked out some other maintenance items and left something loose and or off. Something like the air filter box or along those lines....
Not common. When you say a few seconds do you mean <10s or perhaps more?Thanks for the reply, it's a 3.5 petrol and it was just a oil change using mobil 1 and a Blueprint filter(not Mitsi but good as) I will check it over and see if anything is loose.
Maybe....filter has valve to keep from draining but valve not working
Start up needs to fill filter so oil pressure low and computer turns the idle up?
