rnArmy
So I got it all painted up and put together. I also got a receiver mounted lunette ring (2.5" diameter hole).
Just for fun, I took the lunette ring out and took my magnetic angle finder and went to my pintle hitch on the Jeep.
Side-to-side measurements (twist): 28-30 degrees
Up-and-down measurements: 90 degrees up and 90 degrees down
Left-to-right: 180 degrees.
Then I took the 1 7/8" ball coupler, and took some measurements using the ball mount.
Side-to-side (twist): 18-20 degrees
Up measurement: 15 degrees (not much)
Down measurment: 10 degrees (even worse)
When we took the trailer for a test run, the only clanging we heard was the lunette ring rattling in the receiver tube. So I'll probably drill a hole on the bottom of the tube and weld a nut there so I can thread a bolt in to take up the slack (it's not much, but enough to make a noise).
With this set-up, the trailer sits level with the Jeep when connected.
