happy jack vs torklift
Pacific Northwest yetti
Expedition Medic
I have an 2004 chevy 2500 crew cab short box, w a chip,cold air intake,airbags and custom dual cat back excht.
I am looking at a wolfcreek 850, wet weight will prob be around 2500ibs( its 2008ibs dry) I was kinda thinking i like the happyjack system w/ the fast guns but would love to hear your advice. I do offroading, exploring, SAR, MEDIC work all over.
I was just wondering what you guys recommended, what you are running on your rigs. what works and what does not! thanks
poriggity
It's all a matter of personal preference. I have happijac units on my 04 Dodge 2500. I know quite a few people with torklift that are happy. I don't think you can go wrong with either setup.
Cell Block 726
I've been wondering the same thing, as a proud new owner of a lance 825! I just bought mine this past weekend and pulled off the Happijack system from the seller's 06 Chevy 2500. Looks pretty straight forward and should work ok on my 2500!
poriggity
I will say, with first hand experience, the happijac system is easy to install. I did everything myself, with the exception of starting the bolts for the front brackets, because I needed an extra set of hands helping me line up the front brackets with the bolts.. Other than that, it was a no brainer, really.
Scott
cnynrat
I have a Bigfoot C25 10.6, so it's a fair bit heavier than your camper. That said, to me there is no contest: Torklift.
I originally had the Happijack system installed, and I found that it allowed a great deal of movement by the camper. Most of that seemed to come from flexing of the bed and bumper where the Happijack brackets were mounted. We did have the brace that ties to two front mounts together across the front of the bed.
The newer Happijack system that is advertised as "frame mount" is still basically mounted to the truck bed with a link down to the frame. The rear mounts are only mounted to the bumper as I understand it. Both front and rear Torklift mounts are mounted directly to the frame, which gives a much more secure feeling on the road.
The only downside I see to the Torklift is ground clearance, but with a relatively heavy hard-side camper I don't think that's very relevant for most applications.
motrhed
FRAME MOUNT!!!
I highly recommend connecting the 4 camper tie-down points to the frame of the truck at each corner regardless of the camper size.
Attaching to anything other than the frame is just adding another failure point (bumper, box, etc) particularly in high winds or rough roads.
Torklift manufactures frame mount brackets for most applications or go with a custom built set. I built a custom set of brackets that attach to the side of my Chev HD frame and tuck up close to the body. It's like having a receiver hitch at each corner then extension tubes are inserted that ultimately connect the tie-downs to the camper.
Mounting it right the first time is much cheaper than repairing the damage caused by a weak tie-down point.
morrisster
I have a torklift system on my 3500 duramax with a pop up camper on it. (also using fastguns) - very much worth the investment. I am completely satisfied with how it works, its very easy on and off if you do that (mine stays on the truck). I installed the torklift parts in a few hours by myself - I had some trouble installing the rear ones because there wasn't enough clearance with the factory hitch - I ended up attaching the torklift parts then jacking the factory hitch back into place and it worked fine. its a wonderful very secure system.
Expedition Medic
Thanks guys lets keep this thread going,
I agree with a heavy camper there is no contest and a direct frame mount should be used. But from the standpoint of a Rancher i know what miles and miles of rough road can do to anything. My drive way alone is a 4 mile rough road trek one way. I can see how attaching to anything that is not completely solid allows for extra flex.
motrhed
FRAME MOUNT!!!
Motrhed,
I am able to to fab as well, do you have a thread with pics of your system? Also is you're camper a heavy unit?
motrhed
Yeti,
I don't have any pics of the brackets and I am away from that truck for another week or two. I will try to remember to take and post a few pics when I get it back.
My TC is a Corsair 9'2", it does not have a slide but it a heavy unit, not a brute, but not light. Aluminum framed, hard wall, well insulated, double glazed windows, good sized fluid tanks, basement, etc. Fully loaded (truck and camper), I am running around 9000 lbs (+ or - 100).
Regcabguy
Oil eater.
Happijac fan.
I've enjoyed the Happijac framemount system on two Dodge CTD's with my Northstar TC800. The centering system up front keeps the camper planted and the bumper mounted rear tiedowns have given me no issues. I do wish I had the Fastguns,but my camper rarely comes off.
Hopefully a rear bumper that can take a hit is in my future,so the button setup would be bolted to something other than thin steel. I would like to buy and mount Happijac's rear centering guides soon also.
motrhed
There has not been a substantial OEM bumper on any full size truck built since the 80's, they are all made out of "cheese"!
I wouldn't trust them strength wise to secure or tow anything... just my opinion.
cnynrat
X2!
The flimsy bumper on our '99 F350 was a big part of the reason why we went away from the Happijacks and installed Torklifts.
olsen_karl
I installed Happijacs with the "frame mount" tie-in and the centering kit on my 2000 GMC Sierra. The centering kit really helps line up the camper and keeps it from moving side-to-side. I have a rubber bed mat under the camper too, but there was still some shifting during dirt road driving, until I got around to installing the centering kit. FWIW, this is for holding down a Northstar pop-up camper; guesstimating total weight at around 2000 lbs wet + loaded.
When I bought the camper, it came with Torklift tie-downs, but for a Ford truck. The Torklift hardware is much heavier-duty than the Happijac stuff, so if you have a large, heavy camper (most hard wall ones), I think that would be the way to go. The Happijac kit is much less expensive than Torklift. I sold the Torklift kit on craigslist. Since my camper almost never comes off the truck, and I drive on dirt/4WD roads with it, I wanted the better ground clearance of the Happijac kit (I also removed the camper jack legs and stored them).
IMHO:
Torklift advantage: strength, appears easy to install (I think most of their kits use existing frame holes, so supposedly no drilling involved). Disadvantage: ground clearance, expense.
Happijac advantage: light weight, inexpensive, good ground clearance. Disadvantage: kind of a PITA to install (drilling into bed, holding the front "ear" brackets in place while trying to thread bolts through bed wall -- my dull drill bits didn't make this any easier), not as reassuringly heavy-duty as the Torklift stuff.
There is a Happijac rear bumper brace tie-in kit for Ford trucks. According to Happijac, the Ford rear bumpers are flimsier than the Dodge or GM trucks, and need reinforcing in order to use the Happijac "button" mounts on the bumper.
FishPOET
All stock rear bumpers need reinforcement if you plan on using the Happijac system.
Cell Block 726
I have been apprehensive on installing the happijac setup that came with the TC I just bought...so I went and got some torklift mounts and will just try and sell the happijac on CL..
vertical.dan
